Hooking Dryer Up To Exhaust Outlet - Appliances - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 01:14 PM   #1
Hooking dryer up to exhaust outlet
I have read that a dryer should not be hooked up to a flexible hose since it is a fire hazard due to dryer fluff collecting in the hose. This leaves you with the steel or aluminium piping. The issue is how to connect the silly thing to the back of the dryer and the hole in the pipe that comes in from the outside when the holes a different heights.
I there some trick to this aside from having to be a double-jointed acrobat to try to get these things aligned, taped and/or connected with a metal tightener?
Thanks,
Mike
mfrenette is offline   Reply With Quote
Old 02-17-2013, 01:27 PM   #2
Civil Engineer
Rewards Points: 4,526
Not quite sure what your issue is. I have a dryer hooked up to rigid galvanized steel piping, with two bends before it exits outside through the sill beam. Attaching was very simple, I simply purchased two adjustable bends which can be rotated in three dimensions. They have standard couplings to 4 inch galvanized pipe, which is push fit, followed by taping with aluminum tape (no screws which can attract lint). One of the bends goes on the outlet from the dryer, and one goes in about three feet from the outdoor exit. I put the pieces together one at a time, and adjusted the bends to make the fit work correctly. Certainly it would have been much more difficult, maybe impossible, to make my setup work with rigid ninety degree bends.
Old 02-17-2013, 04:35 PM   #3
Rewards Points: 6
A picture would help.
Dan
djlandkpl is offline   Reply With Quote
Old 02-17-2013, 04:59 PM   #4
Rewards Points: 12,882
http://www.amazon.com/DAF2-Skinny-Te.../dp/B00009W3GR
There''s nothing wrong with a flexable line, just do not use the cheap plastic or foil type.
Old 02-17-2013, 06:01 PM   #5
MarginallyQualified
Rewards Points: 2,464
They watched TOH this morning.
The had another "lets scare the public about X" session.
This week it was dryer vent materials.
Old 02-17-2013, 07:01 PM   #6
Nest Home Improvement
NestHI's Avatar
The appliance section at your home improvement center should have what you need for your exhaust pipe.
Home improvement simplified! Serving the Triangle (Raleigh, Durham, Chapel Hill). Please visit us at www.NestHomeImprovement.com
NestHI is offline   Reply With Quote
Old 02-17-2013, 10:37 PM   #7
Registered User
Rewards Points: 4,936
As said already, the transition duct (in dryer room only) or hose needs to be metal flex it has to terminate there, less than 8' long; fig. 60;http://www.codecheck.com/cc/ccimages...6th_Sample.pdf
The periscopes are very bad because they restrict air-flow, IMO use the metal flex, short as possible to a rigid metal duct;
More info for you; http://www.ashireporter.org/HomeInsp...st-Systems/161
Gary
Old 02-17-2013, 10:54 PM   #8
Dryer fires are no joke nobody is trying to scare the public with bs it is a fact. If you dont think so check with your local fire station for the facts and figures or just google it. Dryer fires happen with freqency.
rkentzel is offline   Reply With Quote
The Following User Says Thank You to rkentzel For This Useful Post:
Dave Sal (02-20-2013)
Old 02-20-2013, 12:28 AM   #9
Dave Sal's Avatar
Rewards Points: 576
Here's a video showing the different air flow rates of various vent designs. Some can make the dryer work harder while others make it more efficient.
Dave Sal is offline   Reply With Quote
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
dryer on a 220 outlet bigbadborders Electrical 2 10-10-2011 02:39 PM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 09:47 PM
Dryer outlet Davide Electrical 3 02-25-2009 12:48 PM
Running AC off of a Dryer Outlet TheCrow Electrical 7 06-16-2008 08:11 PM
