Hood Fan Lighting - Appliances - DIY Chatroom Home Improvement Forum
Old 07-22-2015, 07:27 PM   #1
Rewards Points: 14
Hood fan lighting
Kitchen Aid hood fan model KWCU405SSS.
Originally came with two Halogen MR11 bulbs. I picked up two LED bulbs, put them in and noticed they don't turn off. Replace one LED with a Halogen bulb and they turn off. Put a non contact voltage detector on the wires and it lights up indicating voltage to the wires no matter if the switch is on or off. I guss I'm under the impression that off should have zero volts and on low/high setting would have voltage. What can cause this? Did the electrician hook this up wrong? Fault with the internal parts or is this normal?
Thanks in advance
tron113 is offline   Reply With Quote
Old 07-22-2015, 07:38 PM   #2
Rewards Points: 13,968
#1, loose the non contact tester.
Use a real volt OHM meter to know the real voltage readings.
Can not imagine how the type of bulb would have any effect on how the switch works.
Old 07-22-2015, 07:54 PM   #3
Rewards Points: 14
So I'm getting around 2v when the switch is off...I'm thinking the 2v is there all the time and not enough to light up the Halogen but enough to light up the LED.
Old 07-24-2015, 07:19 PM   #4
Rewards Points: 386
Call the manufacturer's number for service and ask them if you can use LED lamps in the unit.
ChuckF. is offline   Reply With Quote
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 01:35 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
