Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-09-2010, 08:01 AM   #1
Hood fan installation
I am in the process of replacing a builder's hood fan with a Kobe undercabinet one. The new one is much heavier (35lbs), and I am concerned about this. The under cabinet piece is particle board with melamine.
The instructions just say use 4 screws (which were not provided), but will this be truly sufficient to handle the weight?
Kevin
Kevin_M is offline   Reply With Quote
Old 08-15-2010, 04:49 PM   #2
If the cabinets have been installed properly, you shouldn't have an issue. If you want you can use machine bolts, washers and lock nuts.
Ron
Old 08-16-2010, 02:11 PM   #3
Kevin
whats the weight of the old one ?
BronzeGenius is offline   Reply With Quote
Installation of range hood vent duct. gante Roofing 9 09-23-2010 10:41 AM
Range hood installation problem Lucas718 Appliances 4 08-16-2010 02:28 PM
Hood / Vent Requirements for Gas Stove WaldenL HVAC 1 09-09-2009 04:38 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Range hood installation, termionating at ceiling gorf Appliances 3 12-04-2008 10:28 PM
