Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-19-2012, 12:24 PM   #1
Honda pressure washer
honda pressure washer, water wont flow through pump
chris Bowen is offline   Reply With Quote
Old 05-19-2012, 06:06 PM   #2
jschaben
Have you done any trouble shooting at all? I've seen Honda motors on all different brands and types and sizes of pressure washers.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 05-19-2012, 07:42 PM   #3
Will it flow water without the hose hooked up?
Does any water come out at all ?...even a trickle?
Can you post a picture o the pump on the bottom? Usually the pump is made by a different manuacturer than the name on the top.
I have ixed a couple o these that had bad "O" rings in the pump and pieces block the outlet ports.
danpik is offline   Reply With Quote
Old 05-27-2012, 05:41 PM   #4
Household Handyman
What is your area? When was the last time you used this machine? Good question: Will any water go through the pump with the input water supply hooked up and the pressure washer hose NOT hooked up? The number one problem with most big box store pressure washer's will be rusted internal check valve parts. ALL pressure washer pumps DO NOT necessarily have Stainless Steel internal parts. The majority of these big box store unit's pumps are mass produced for a particular manufacturer seeking the lowest cost they can pay for a pump assembly. IF the motor will fire up, and the coupling to the pump is not compromised, then the rotating internal parts may be working, that does not mean the valves are not rusted up OR even have a tiny piece of trash in one/both valves which renders them useless. Depending on how competent you feel you are with your own pressure washer's pump: Try "Googling" the brand name of the PUMP, not the unit itself, use the model/serial number and you will probably be able to find a repair and/or parts manual online for yours.
Old 05-27-2012, 06:37 PM   #5
jschaben
I think this thread is done. OP's last activity was 1 minute after he posted.
John Schaben
Has anyone built a hot water pressure washer ? Sin-city-custom General Discussion 5 02-25-2011 06:32 AM
Looking for a motor capactitor for pressure washer andy1033 Electrical 0 10-07-2010 08:05 AM
pressure washer on well water Hardly Handy Plumbing 3 09-06-2010 09:16 PM
Pressure Washer Manifold Replace DIY JIM Tools 3 10-13-2009 08:50 PM
What to look for in a Pressure Washer ? Scott_K Tools 5 07-03-2005 02:43 PM
