-   -   Honda generator (http://www.diychatroom.com/f47/honda-generator-71917/)
kev/urbenville 05-23-2010 06:31 PM
Honda generator
Gday, Ihave a 7KVA Honda generator that will only run on full choke im thinking this may be why the motor start capacitor on my compressor burnt out when i used one to run the other am i getting a fluctuating voltage that could have caused the failure or is it supposed to run on full choke? The compressor hase a 2.2 kw/3hp motor, is the genset big enough? Thanks guys your thoughts would be appreciated, Kevin.
Yoyizit 05-23-2010 06:34 PM
The engine is running way too lean?
boman47k 05-24-2010 08:56 AM
Four stroke, right?
May have some blockage somewhere in the carb.
One thing that might work is to remove the filter so you can see the throat of the carb. Spray bursts of carb cleaner in the carb to help remove any blockage. Do this repeatedly until it runs without the choke being on.
This has helped me with my gen's when they have sit for a while and the gas may have left a varnish residue in the carb passages.
May be necessary to remove carb and clean really good and rebuild.
Might want to check all fasteners to make sure the carb itself has not worked loose and is sucking air. Remove the fuel line where it connects to the carb and see if gas is flowing freely to maybe rule out and clogged fuel filters.
kev/urbenville 05-25-2010 03:22 AM
We are on the right track
I have flushed the fuel lines, removed the carbie and there was a brittle scale on the inside and chips were flaking off, reckon this may be part of the problem, i found it difficult to remove completelly, ill try that carbie cleaner and let you know how i go, thanks for your thoughts.Kev.
boman47k 05-25-2010 07:23 AM
That carb may need to be disassembled and soaked to get that scale out of the little passages. Sounds as though it may have sit for a while or seldom used. If you reinstall the carb without soaking it in cleaner, squirt the carb throat and start it. It should run start and run momentarily. When it starts to die, squirt it again. Do this several times, and it may take several times if it is scaled that bad. Hopefully, after a few suirts, you can start taking the choke off,
If it sits a lot, like mine do, you may want to get some fuel stabalizer to add to the gas in the tank. Or, run the carb dry of fuel when you put it up.
