Help Please! Maytag Dryer Not Heating - Appliances - DIY Chatroom Home Improvement Forum
Old 12-27-2009, 01:04 PM   #1
Help Please! Maytag Dryer not heating
Are these dryers that difficult?? The dryer starts to heat then 1 min. later the gas flame kicks off. I was told it is a voltage problem? The outlet is good, the plug is good, the timer has 120v going to it. The gas valve coils ohm out at (3 prong- between 1-2 @ 1,369 1-3 @ 560) (2 prong between 1-2 @ 1,298) not sure if these are good or not? I was instructed to change these coils out. Help Please!
paparoach is offline   Reply With Quote
Old 12-27-2009, 05:36 PM   #2
I had the same issue on a dryer recently. Dryer would start, I would leave thinking it was working and then get calls from my Tenant's asking why the dryer was not heating up. I did not fix it personally (had my guy take care of it) but if I recall he said that it was the solenoid that was bad. I have personally taken the dryer apart and they are really not that hard to work on. For sure it is not a voltage problem though.
Check this out. Might help
http://www.acmehowto.com/howto/appli...ck/gascoil.php
jbraun is offline   Reply With Quote
Old 12-27-2009, 05:45 PM   #3
Post a schematic.
Old 12-29-2009, 08:08 PM   #4
Maytag Dryer
Ordered two coils from Appliance Parts Pro's .com got them the next day and half price, installed and I have heat.
thanks for your help
Old 12-30-2009, 05:24 AM   #5
an easy way to tell if it's coils is; the igniter will cycle on and off w/o flame.
Jacques is offline   Reply With Quote
Maytag WASHER / GE DRYER CAPACITY ?? Chemist1961 Appliances 5 08-26-2009 08:34 AM
Maytag gas dryer problem Rick V Appliances 2 02-08-2009 01:48 PM
Maytag Dryer Squeel DIYLI Appliances 1 03-30-2008 01:43 PM
electric dryer heating element gooch Appliances 2 03-27-2007 09:31 PM
