Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-11-2009, 09:45 PM   #1
Help! My dryer keeps wearing out rollers!
Okay.
I have a Kenmore dryer that is roughly 5 years old. Over the last two years I have replaced the bottom roller no less than five times! Each time I open it up, the rubber on the roller is worn like it is being split down the middle. Each time everything feels like it is going back into place correctly when I put it back together but somewhere between one and two months later, the noise is back and I know the wheel is worn out.
I am one repair away from taking it out into a field and shooting it... a lot.
JDokter is offline   Reply With Quote
Old 03-12-2009, 07:25 AM   #2
J Calvin Construction
jcalvin's Avatar
You aren't using it to mix concrete are you?
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 03-12-2009, 07:29 AM   #3
dSilanskas's Avatar
Sounds like a bad dryer
dSilanskas is offline   Reply With Quote
Old 03-12-2009, 11:09 PM   #4
Nope, just normal laundry for a family of three.
Old 03-13-2009, 11:11 AM   #5
What kind of gun were you thinking of using?
gma2rjc is offline   Reply With Quote
Old 03-14-2009, 07:04 AM   #6
Mine is getting noisey again after about 8 years, but it's 30 years old. Replace the pads up front and the shaft and bushing at rear. While you're in there clean the vent duct inside and inspect your belt for cracks and check the element.
THEN CHECK IT FOR LEVEL. IF IT IS RUNNING OUT OF LEVEL ON A SLOPED BASEMENT FLOOR CENTRIFIGAL FORCE IS YOUR ISSUE.
Chemist1961 is offline   Reply With Quote
Old 03-14-2009, 07:24 PM   #7
Ok never thought about it being level. I'll definately check that. The last go round I replaced the heating element and the belt is about a year old at best.
Old 03-17-2009, 09:38 PM   #8
HVAC / Plumbing
Is it the same roller each time of both ? If it's the same 1 . something is out of alignment
kenmac is offline   Reply With Quote
Tags
dryer noise, rollers
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Dryer vent ponch37300 General Discussion 10 01-21-2009 05:26 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
