Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-20-2012, 08:48 PM   #16
#1 HAWKEYE FAN
hardwareman's Avatar
Help with microwave installation.
Originally Posted by NitroNate View Post
can the microwave be attached from above somehow? might take a little ingenuity but it's better than falling off. maybe look at reinforcing the back panel from behind and then screwing into that.
of course it can be attached from above, that is how they hang from the cabinet. bolts screw down from the upper cabinet into the micro. His problem is the rear support that needs to screw into studs will be screwed into nothing but a 1/4" piece of backer board. Not really an ideal install.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-20-2012, 08:53 PM   #17
#1 HAWKEYE FAN
ok here is what I would do. Since you said you don't mind the toggle bolts going through the back panel, why not take a piece of 1/2" plywood. Cut it the exact same dimensions as your micro wave back. Screw it to the backer panel from the opposite side of the micro with about 6 or 8 black headed screws. That way you have a good solid backing to screw you support to.
Old 09-20-2012, 10:24 PM   #18
DIY Enthusiast
sublime2's Avatar
I would screw through the panel into the ply.
Again,MW will hide any screws AND more of the screw is grabbing the ply and not the panel.
Oh,and the MW doesn't hang from the cabnet.
It is bolted to it.
sublime2 is offline   Reply With Quote
Old 09-21-2012, 12:11 AM   #19
#1 HAWKEYE FAN
It is bolted to it.
I don't think you still understand
Old 09-25-2012, 12:13 PM   #20
thanks for the good advice. I guess my options are trying to mount it from the cabinets on both sides, or as hardwareman suggested, creating a bracket and hang from above
wheelds is offline   Reply With Quote
Old 09-25-2012, 12:15 PM   #21
it is a little discouraging that no one has come across this type of issue/mounting solution before
Old 09-25-2012, 04:04 PM   #22
Thanks for all the advice so far hardwareman - i like your idea with a sheet of plywood accross the back with the MW bracket. What do you think about using hurricane ties and attaching them into the side cabinets for additional support/stregnth.
Old 09-25-2012, 08:43 PM   #23
#1 HAWKEYE FAN
overkill
Microwave Installation donmigga83 Appliances 8 04-12-2012 11:38 PM
Microwave Installation Sandy1 Appliances 15 10-12-2011 11:20 PM
Microwave hood installation wilderstyle General Discussion 3 09-10-2010 06:10 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 08:55 PM
