09-19-2012, 11:33 AM
#1
Help with microwave installation.
Hell All,
I am replacing my appliances in my house and I have come accross a dilemma with my microwave. I DO NOT have wall studs on the back of the microwave. I have read threads here where posters are calling people crazy for not finding the studs on the wall, were below is proof. I have a 1/4 cabinet backing that the old microwave was mounted to.
So i am looking for ideas on installation. I am installing a Samsung smh1713s microwave. I have considered using anchors and drill through the cabinet backer but realling looking for advice on the best solution for mounting. Thanks in advance.
09-19-2012, 06:10 PM
#2
#1 HAWKEYE FAN
are those cabinets just hung from the ceiling???
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
09-19-2012, 07:01 PM
#3
Yes
Cabinets on the left side are mounted to the wall and you can see the support on the right side at the bottom and they are screwed in to the ceiling above using U bolts I think
09-19-2012, 08:58 PM
#4
#1 HAWKEYE FAN
don't believe I've ever seen that before, anyway you'll have to hang the new micro the same as the old. Mount the micro bracket to the 1/4" panel, most of the support will come from the bolts in the upper cabinet
09-20-2012, 11:11 AM
#5
what would you recommend for mounting the MW bracket to the backerboard? The old bracket was screwed in with tiny screws that didn't even grab into the particle board. I am amazed the microwave never fell.
I was looking into using toggle bolts or something similar. I am not opposed to drilling completely through the backerboard, i just want it to be clean as possible.
09-20-2012, 11:27 AM
#6
DIY Enthusiast
Whats behind the backerboard?
Brick? Drill holes in brick put anchors in the holes then secure.As stated already,most support will come from securing to the cabinet above it.
Toggle bolts won't work if there is no space between board and brick.
09-20-2012, 11:34 AM
#7
maybe backerboard was the wrong word to use. Its a cabinet beauty panel? that lines the backside of the cabinets in the picture. Its only about 1/4" thick so any kind of anchors will not work.
09-20-2012, 12:05 PM
#8
DIY Enthusiast
So behind the beauty panel is sheet rock?
Toggle bolts will work.as for clean holes,you will not see them as the MW will cover them.
09-20-2012, 02:40 PM
#9
Looking at the picture in my first, i want to mount my new microwave in the existing space. It is cabinets suspended from the ceiling. The backside of the cabinets (what is seen from the dining room, living room) is beauty board stained the same as the cabinets. I have no sheet rock, no studs, nothing else but the 1/4" board on the back of the microwave to mount to.
09-20-2012, 02:41 PM
#10
i guess i can better explain this with a new picture with my old microwave removed. I will upload one when i get home.
09-20-2012, 06:24 PM
#11
#1 HAWKEYE FAN
not sure what else you can do besides mount it the same way the other one was.
09-20-2012, 06:45 PM
#12
#1 HAWKEYE FAN
toggle bolts are probably not a good idea, I don't think you want them big ole things sticking out the back side.
09-20-2012, 06:46 PM
#13
#1 HAWKEYE FAN
he has nothing behind the backer panel, no wall no brick no nothing. Cabinets are hung from the ceiling only, that is his problem
09-20-2012, 06:47 PM
#14
can the microwave be attached from above somehow? might take a little ingenuity but it's better than falling off. maybe look at reinforcing the back panel from behind and then screwing into that.
09-20-2012, 07:43 PM
#15
DIY Enthusiast
Thanks for the clarification!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
