Help Me Please- Dishwasher Leaking - Appliances - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 05:44 AM   #1
supermarvin76's Avatar
Question
Help me please- Dishwasher leaking
My dishwasher (Whirlpool Gold Quite Partner III) has a "slight" leak out the door. When I look at the bottom of the door, I see about 5 holes which appear to be there as part of the manufacturing process.
The leak looks to be coming from the middle hole. Anyhow, I concluded I should be able to take the door pannel off and easily see where the leak was coming from. No such joy. I looked all around the inside of the door and can't seem to find anything.
I messed with the little flapper seal up by the air vent thinking that may be loose, and looked for leaks around the detergent area- nothing overly obvious to me.
I put it all together and ran one cycle with no leak. I ran another cycle yesterday and now the same pesky leak is back .
Please send some advice my way!
Thank you!
supermarvin76 is offline   Reply With Quote
Old 01-04-2013, 05:18 AM   #2
I stopped by a local appliance store and as fate would have it, they're not up to par with Whirlpools. They still tried to help me though.
I ended up ordering the "U" seal that seals the door to the tub.
Hopefully it will be into for me to pickup today.
I'll stay posted.
Old 01-04-2013, 07:19 AM   #3
Rewards Points: 3,130
I had a similar issue with my LG dishwasher - at least a quart of water every time I used it. Since the leak was actually from inside the door, a new seal would not fix the problem. This is when I discovered to my chagrin that this is a common problem with LG's dishwashers, and their customer service is the worst in the industry. Their only "solution" was to sell me a complete door assembly for almost $200. But mysteriously, the leak stopped six months ago and has never returned. Got my fingers crossed.
What really frosts me is that this was a very expensive unit (almost $1000). Every other dishwasher I've ever had was builder grade, and none ever leaked.
Tags
dishwasher , dishwasher leak , leak , whirlpool
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
Leaking Dishwasher md2lgyk Appliances 11 04-30-2012 12:47 PM
Maytag Dishwasher Leaking at Air Inlet Thunder Chicken Appliances 3 03-22-2012 02:27 PM
Water leaking out left side vent(?) of Dishwasher Barkley Online Appliances 8 01-14-2011 12:42 PM
Leaking Dishwasher Clean-up teamcanada Plumbing 0 06-23-2010 02:16 AM
