Help With Maytag RefrigModel MSD2454FR? - Appliances - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 03:58 PM   #1
Help with Maytag RefrigModel MSD2454FR?
I purchased this model new approx 5-7 yrs ago. It worked for 4 months! First the water dispenser would not stop running water-I solved that. In less than a year & since the icemaker will not make ice! The water runs now. Now the refrigerator has stop cooling, 44-50 degrees & after we open the door, within 5-10 min. water is on the floor. 3 different service companies over the past several years & over $400 in repairs & within 4-6 months its doing the same thing! I'm about to try another service call Sat, but would like to know what is the probable cause? I hear the fan. I have had a little small box that appearrs to be about 2 inches wide replaced each time? I've vaccumn. I have not had a decent refrigerator since my first 12 years ago. An answer is appreciated. Ive had every standard model except GE.
gnagirl is offline   Reply With Quote
Old 07-22-2010, 07:51 PM   #2
lloydb's Avatar
That would likely be the defrost timer. Maytag had to send someone out replace the defrost timer on my fridge the first week I had it. Hard to say what your present problem is.
If I were to buy a new fridge for my house it might likely be a samsung. Weve done the circle with different brands at work and I can tell you that GE is no better. I've had to shim the freezer door on a ge right out of the box to get it to close properly.
Broken Arrow hvac Broken Arrow Air Conditioning
lloydb is offline   Reply With Quote
Old 07-22-2010, 08:02 PM   #3
Maytag range LP back to NG jdoff Appliances 9 10-23-2013 12:59 PM
Maytag Washer won't work nuclearjesus Appliances 7 04-24-2010 08:17 AM
Maytag dishwasher upper sprayer arm agarwal450 Appliances 3 06-21-2008 09:49 PM
Maytag refrigerator problem gachar001 General DIY Discussions 1 05-01-2008 04:38 PM
Maytag Dryer Squeel DIYLI Appliances 1 03-30-2008 01:43 PM
