I maytag dryer will not heat up it's a gas dryer everything works but no flame, even the light thing next the gas coil,it lights up but it dies down after a seconds or maybe a min not more, but no flame
Back again same problem,I have changed the gas valve coils but the problem remain no flame,the igniter lights up but shuts off after a few seconds,all I got was a click sound and then it turns off,i checked all the thermostats and they are all good, all of them have continuity, there is gas going to the gas valve, I'm positive that's the case because I turned on the gas while the coil right next to the regulator ,on the gas valve was removed, and there was gas coming out of it, I'm really frustrated now as to what is preventing the gas from been release by the coils, help please.
some newer appliances have a circuit in the ignitor that checks for current flow when the ignitor is on. If the current flow is too low it does not see the ignitor as on and will not open the gas valve even if the ignitor is glowing. I do not know if this particular model dryer has this feature or not. Some research may be in order.
part# W10116794, highly recommend using exact part
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
