-   -   help !!!! Maytag dryer model LDG 410 no flame (http://www.diychatroom.com/f47/help-maytag-dryer-model-ldg-410-no-flame-151539/)
Gates 07-25-2012 08:17 PM
I maytag dryer will not heat up it's a gas dryer everything works but no flame, even the light thing next the gas coil,it lights up but it dies down after a seconds or maybe a min not more, but no flame
beenthere 07-25-2012 10:01 PM
Moved to Appliance forum.
hardwareman 07-25-2012 11:32 PM
gas valve coils are bad
Gates 07-26-2012 01:39 AM
How can I check gas valves ?
Pedrin 07-28-2012 09:45 PM
If there is gas getting to the dryer then just replace the coils as stated above.
Gates 07-30-2012 09:54 AM
We appreciate it !,I'm waiting on the replacement coils I hope that should do the trick
Gates 08-01-2012 04:38 PM
Back again same problem,I have changed the gas valve coils but the problem remain no flame,the igniter lights up but shuts off after a few seconds,all I got was a click sound and then it turns off,i checked all the thermostats and they are all good, all of them have continuity, there is gas going to the gas valve, I'm positive that's the case because I turned on the gas while the coil right next to the regulator ,on the gas valve was removed, and there was gas coming out of it, I'm really frustrated now as to what is preventing the gas from been release by the coils, help please.
danpik 08-06-2012 02:05 PM
some newer appliances have a circuit in the ignitor that checks for current flow when the ignitor is on. If the current flow is too low it does not see the ignitor as on and will not open the gas valve even if the ignitor is glowing. I do not know if this particular model dryer has this feature or not. Some research may be in order.
Gates 08-06-2012 02:26 PM
1 Attachment(s)
Attachment 55352
This is the diagram for this particular model
hardwareman 08-06-2012 06:29 PM
you will have to replace the entire gas valve assy.
Gates 08-06-2012 06:44 PM
Would it be wise to convert to a newer type gas valve
hardwareman 08-06-2012 11:21 PM
a gas valve is a gas valve and you will only be able to get what is available for that model
Gates 08-06-2012 11:30 PM
I check with 2 parts company and they don't carry the k series gas valve I was wondering if I of to use the exact one
hardwareman 08-07-2012 08:48 AM
part# W10116794, highly recommend using exact part
