Help!! I Scratched My Stove Top. - Appliances - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 12:23 PM   #1
Help!! I scratched my stove top.
I used the s.o.s (green side) of my sponge when the stove was hot to scrub food off of it around a large burner. The stove is white and about ten years old. It seems to have scratched the paint off of it. I have done the same thing a lot of times and never had that happen. Is there anything I can do to fix the scratches. Any kind of paint I can use?
Dana1 is offline   Reply With Quote
Old 04-15-2009, 12:27 PM   #2
BIGRED
Rewards Points: 252
If you are actually down to metal try some Appliance White Touch-up paint from an appliance shop.
Grampa Bud is offline   Reply With Quote
Old 04-17-2009, 06:24 PM   #3
Late stage optimist
There are things you can do, but not something I can tell you in print and that you could go do it.
You have to use a progressively finer abrasive (doing it in steps) and use one of several methods to work down to a very very fine polishing to finish it. I am reluctant to spell it out here because if you don't know what you are doing, you will make the problem worse.
I would say if it bothers you to look at it, the best remedy for you will be to call a good appliance store (one that ONLY sells appliances) and ask them for a referral to whoever they use when their appliances arrive or are installed damaged. They have resources for these things, I guarantee, if you call the good places.
fuster is offline   Reply With Quote
3 wire stove connection bgoldie Electrical 13 03-01-2011 12:29 PM
Wood stove ? econdave General DIY Discussions 8 10-17-2007 06:50 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
