Help Fixing Kenmore Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 01:37 PM   #1
Indentured Servant
Help fixing Kenmore oven
This is an older (15) year old Kenmore LP oven, model number 362.75675691. Oven wouldn't lite. I replaced the igniter which I already knew was bad. Broiler igniter is off now, waiting for that part. But the bake burner will still not light. So I checked the gas valve with a meter and it says that it is closed, so it tests good.
Is there a fuse on this thing I am missing? Or do I have a problem with a control relay? Not sure how to test for these things.
jackpine is offline   Reply With Quote
Old 03-23-2013, 10:14 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
check for 110 volts going to ignitor first
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-25-2013, 11:28 AM   #3
Indentured Servant
So test with multimeter while oven is activated I assume?
Old 03-25-2013, 10:43 PM   #4
#1 HAWKEYE FAN
correct
Kenmore Oven Error Code Katigan Electrical 2 03-20-2013 05:13 PM
Kenmore Oven Broiler Kaput...need top fix downdraft Appliances 11 06-17-2012 12:11 AM
Kenmore Oven Element Arcing Valerie1960 Appliances 2 01-30-2012 09:03 AM
Old gas kenmore range....no oven, but burners work shadango Appliances 24 11-17-2010 07:45 AM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 05:45 PM
