Help Diagnosing Sub-zero Freezer Issue - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-08-2014, 08:21 PM   #16
Rewards Points: 14
Originally Posted by beenthere View Post
No fridge keeps food colder then 32 degrees. It would freeze the food if it did.
Charge or restriction in the strainer.
I've been playing around with positioning the thermometer in different spots of the freezer. The top shelf gets the coldest at five degrees where the bottom shelf isn't nearly as cold at 10-15 degrees. Even though the fan appears to be running could it be not circulating well? It seems to blow ok.
harryc is offline   Reply With Quote
Old 06-08-2014, 08:59 PM   #17
An old Tradesmen
Rewards Points: 7,342
Its possible.
Old 06-11-2014, 09:30 PM   #18
Rewards Points: 125
Most likely it's an oil logged cap tube. We see this type of stuff all the time on Ultra Low Freezers (-80C).
You have to defrost them for at least 24 hours annually. Otherwise the cap tubes get built up with oil and they won't pull down to temp.
Try it...and see if it pulls down to where it should be.
bilug is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 10:32 PM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
freezer leaking into fridge - cannot locate drain hole pro_DIYer Appliances 5 12-31-2008 11:08 PM
Freezer on top, not freezing any more. kgphoto Appliances 7 06-23-2008 10:00 PM
