Heat Pump - Appliances - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 09:26 PM   #1
heat pump
My heat pump (Panasonic) has a built in frost cycle. Where I live, in winter, it gets frost every night and sometimes all day, and the heat pump constantly turns itself off, to defrost the outside motor. Is there any way that cycle can be turned off?
judim is offline   Reply With Quote
Old 06-15-2011, 09:51 PM   #2
You might have better luck if you try the HVAC section. Model #'s, etc... really help when trying to make a long distance diagnosis.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
judim (06-16-2011)
Old 06-18-2011, 08:45 PM   #3
Why would you want to turn the defrost cycle off? If you did that, the outdoor coil would freeze completely over and it would no longer be able to move air through it and therefore not heat your home.
When it goes into defrost their should be electric auxiliary heat strips in the indoor portion that kick on and heat your home while the outdoor unit is defrosting itself. If this isn't happening then your system is not wired correctly.
Kevster is offline   Reply With Quote
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
