Good Old Montgomery Ward Refrig HMG 1400-0 With Bad Smell - Appliances - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 02:51 PM   #1
Rewards Points: 317
good old Montgomery Ward refrig HMG 1400-0 with bad smell
I took all the food and cleaned inside. Did not see any standing water in refrig or top freezer. It is cooling just fine. The only hole (drain?) I could find is under the veg/fruit bin. I put a Q tip down that hole; it came up clean.
Does leaking freon have a scent? I can smell whatever it is from the dining room when the refrigerator door is closed, but not as much as when the door is open, so any clues would be appreciated...
DIherself is offline   Reply With Quote
Old 08-01-2012, 07:08 PM   #2
Rewards Points: 83
Refrigerant itself doesn't smell a whole lot. The oil does though. You can try wiping the unit down with disinfectant or cleaner.
Protocol. is offline   Reply With Quote
The Following User Says Thank You to Protocol. For This Useful Post:
DIherself (08-02-2012)
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 07:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Studor Mystery: Sewer Gas Smell StudorCrazy Plumbing 3 02-20-2010 12:49 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
