Glow From Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 10:01 PM   #1
glow from dryer
Hello. I have a 15 yr old Whirpool dryer and recently noticed a "glow" coming from behind the dryer. It is towards the floor and when I turned the dryer around I could see the glow coming from one of the louver vents. The glow was periodic (i.e. it was on for a while, then off, then on, and so on.) Is this just the normal heating element or is there a problem? I've had the dryer for a few years, but I only recenly saw the glow...that said I never really looked for it before with the lights off. You cannot see the glow with the lights on.
Thanks for your help
tthacke is offline   Reply With Quote
Old 01-07-2009, 01:00 AM   #2
Rewards Points: 2,906
It's probably just the heating element being controlled by the high or low temperature thermostats.
Start the dryer with a full load of damp clothes in it on the "Delicates" cycle when the lights are out (maybe use a flashlight). With a full load of damp clothes, the heating element will stay on for a long time to heat the dryer drum and get enough moisture out of the clothes that the air flowing through the dryer heats up enough to turn the Delicates thermostat off.
Once the glow disappears (cuz the Delicates thermostat goes off), and then you open the dryer door (to stop it) and switch the temperature setting to "Regular" or "Permanent Press" and the glow starts again after you close the door, then it's definitely the dryer's heating element working normally.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 08:16 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 10:45 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
