Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-22-2011, 01:36 PM   #1
GFIC tripped in Garage by Fridgidair
I bought a Fridgidair refrigirator (Model#GLRT182SAW4) recently. I placed it in the garage. It tripped the GFIC recepticle every a couple of days. I have to reset the GFIC on the in wall receptical and advanced the timer manually to get the refregirator started again. It run for a coupled day and tripped the GFIC again. I had to start the procedure all over again.
The interval between the tripping appeared random. However, the trippings always happened during defrost cycle.
I have checked teh defrost heater. Its resistance is 65 and looks good to me. I have also confirmed that there is no power to the fan motor (next to the evaporator) during defrost cycle.
Please offer some solutions
n2011 is offline   Reply With Quote
Old 12-22-2011, 04:08 PM   #2
#1 a ref. should be pluged into a GFI outlet.
It needs it's own 20 amp. 12-2 wired circut
Old 12-22-2011, 07:23 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
could be a weak GFCI outlet. When a refrig is in defrost is when it draws the most amperage.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Tags
defrost, fridgidaire, garage, ground fault interupter, refrigirator
Garage floor Tomperro Building & Construction 3 07-18-2011 12:37 AM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 07:47 PM
Garage Ideas? tripflex General Discussion 13 12-16-2009 08:06 PM
