GE XL 44 Range Control Panel Making Noise - Appliances - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 07:20 PM   #1
raylo32's Avatar
Rewards Points: 1,254
GE XL 44 range control panel making noise
The control panel area of my GE range sounds like a refrigerator compressor. Anyone have any ideas what could cause that? Is it repairable? The burners, oven, digtal controls all work fine. I tried powering it down and back up again... no help. It is VERY annoying.
raylo32 is offline   Reply With Quote
Old 10-11-2011, 06:31 AM   #2
XL-44 isn't a model #. it's a marketing designation [big oven=4.4]. i'd be a little concerned. there's nothing in there that should make noise. it have a flourescent light or is this oven gas and the spark module is located there and it's humming?
Jacques is offline   Reply With Quote
Old 10-11-2011, 07:32 AM   #3
raylo32's Avatar
It's a gas range/oven. No flourescent light. I'll pull the control panel cover off this evening and try to pinpoint the noise.
Old 10-11-2011, 04:44 PM   #4
raylo32's Avatar
Took the digital control apart and fund the bugger that is making the noise. See photo below. I think it is the speaker/beeper. I am not sure that this control module can be disassembled to replace this component. Anyone have any experience with these?
Here is the front of the control module for reference:
Old 10-11-2011, 06:30 PM   #5
raylo32's Avatar
OK, I was able to unsnap the control board from the frame parts then it opened up like a clam shell. So... I could easily unsolder and remove the beeper or replace it if I could find the part. I am not entirely sure that the beeper itself is bad though. I guess it could be a bad cap or resistor or somesuch that is throwing it the noise signal? How to tell?? Appreciate any thoughts.
BTW, the range is a GE XL44 Model # JGBP3JWEV4WW Natural Gas
Old 10-12-2011, 07:47 AM   #6
Interesting problem. so i was curious & looked it up. that model # is wrong-assume you meant jgb30wev4. but that model calls for different erc than your picture shows?? that control-wb12k20- had problems with the spark module, causing rf noise and making erc go blank-had to replace both at that time. in any event it's a 1995 date code so erc is nla. i wouldn't screw around with it. if you want to save this range fully functional= check out www.corecentricsoultions.com they'll repair the erc and you'll be ok. i would call first though, with all the #'s avail to you.
Old 10-12-2011, 08:15 AM   #7
raylo32's Avatar
Sorry for the wrong model #. Apparently I can't read my own writing... mistook a 5 for J. Model # is actually: JGBP35WEV4WW
Old 10-12-2011, 04:34 PM   #8
raylo32's Avatar
Here is a video... taken merely since it was an easy way to record the audio. The control seems to work fine so before I send it off to Corecentric or somesuch for remfg I wonder if there is maybe another component in the stove that is throwing off the RF interference and perhaps the contol is OK? Otherwise the range, oven, broiler and all control functions work perfectly. I put it back together and I guess for now I'll just unplug the thing when it's not in use.
Old 10-13-2011, 05:36 AM   #9
raylo32's Avatar
Jacques,
Do you have the GE "WB" part number for the control board (and/or its replacement) for my oven model? The circuit cards aren't labeled as far as I can tell. I have found the part listed on several sites, NLA, of course, but they have local site part numbers and don't provide a cross to GE part numbers. Other sites list only the GE part numbers but don't provide a search by oven model number. Arrrggghhh!
I'd like to expand my search using the real GE part number(s) and if that fails have the real part number to confer with the remanufacturers.
Thanks,
Ray
Old 10-15-2011, 07:34 AM   #10
raylo32's Avatar
Well, I have fixed my problem. I was able to get a new ERC... but only by getting a whole new stove. I decided against spending ~$200 on a "maybe" repair to the ERC on a 16 year old $400 stove. Gotta love the planned obsolescence strategy the mfgs use.... build stuff that doesn't last, make too few repair parts, then overprice those parts. I guess it sells lots of new appliances...
Old 12-19-2016, 03:31 AM   #11
Rewards Points: 2
Re: GE XL 44 range control panel making noise
Hello, resurrecting an old thread, but I wanted to post my own solution to this as I was having exactly the same problem.
It turns out that the high pitched whine is being caused by a faulty electrolytic capacitor which is directly connected to the beeper. You can follow the trace from one of the beeper's terminals to the capacitor. I de-soldered the capacitor and found that it had leaked and died. I replaced it with a capacitor I had laying around that had a similar voltage tolerance but slightly different uF. (In this case, the original was 330 uF and the replacement was 220 uF) This fixed the problem completely.
Posting just in case anyone else searches for this problem and is handy with a soldering iron!
NathanF is offline   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 02:45 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
