GE WCVH6800JMR Leaking - Appliances - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 08:39 PM   #1
GE WCVH6800JMR leaking
We have a GE WCVH6800JMR that suddenly started leaking tonight after just 2.5 years of ownership. Very disappointing.
It is leaking slowly from the center at the bottom center of the door but enough that it created a substantial mess in our basement.
I have verified that the door gasket is not torn in any way that I can see or feel. The gasket does look a bit out of shape at about 2-3 o'clock on the opening of the washer but I believe it's been that way for a while so it doesn't make a lot of sense why this is happening now.
What I find even more peculiar is that there appears to be water inside the door itself as pictured.
Any suggestions and thanks in advance for any help!
agentphish is offline   Reply With Quote
Old 03-20-2012, 09:39 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
it is possible to get water in between the door glass and the trim but I doubt that is your problem. If it is a substantial leak you should be able to see more than a drip. I assume you have run it and watched it drip out the door? You may have to take the bottom panel off and observe. Also double check the door gasket especially the part closest to the drum, get a flashlight stick your head inside there and look all the way around the gasket sometimes them small tears can be hard to spot.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-20-2012, 09:59 PM   #3
Thanks for the suggestions. I will investigate closer tomorrow evening after work.
Old 03-21-2012, 12:40 AM   #4
Also, clean underneath the door window. they get gunked up and you lose your seal- resulting in drip at center bottom.
Jacques is offline   Reply With Quote
Old 03-22-2012, 10:31 PM   #5
I think I found the issue. The small drain area in behind the gasket was all clogged with hair. I'm glad that seemed to fix it for me.
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
