Ge Washing Machine Top Loader - Appliances - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 08:00 PM   #1
ge washing machine top loader
just put on a belt washed a couple of loads the belt breaks again, why?
getherdone is offline   Reply With Quote
Old 11-29-2012, 06:44 AM   #2
Rewards Points: 1,294
Wrong belt, too tight, too loose, pullys out of allignment, bad bearing in pump, bad bearing in motor, bad pump, bad motor, bent motor shaft, bent pump shaft, loose motor mount, loose pump mount, loose drum mount broken drum mount, twisted chassis, or several combinations of the above.
danpik is offline   Reply With Quote
Old 11-29-2012, 10:16 AM   #3
custom user
Rewards Points: 150
Other than that what would cause it?
JasperST is offline   Reply With Quote
Old 11-29-2012, 10:46 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,142
Moon out of phase?
(jasper...that was a funny response....)
Ok....all joking aside....
Belts don't break very often......looking at how it broke will give you an idea of the cause...
If the edges are frayed....alignment....or a pulley is damaging it....
Clean break? Bad belt....
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 01:07 PM
Plumbing or Washing Machine Issue svaic00 Plumbing 4 08-06-2012 09:46 AM
Front Loader Fridgidair Washing machine Banging Noise when Spinning dads gt Appliances 1 04-05-2009 10:22 PM
LG Front loader washing machine repair sharz Appliances 1 04-19-2008 11:30 PM
