Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-02-2012, 07:41 PM   #1
Ge Washing Machine Problem!
My machine is 5 years old. Never a problem until now. Everything works fine until it gets to the spin cycle. The water drains out fine. I hear the motor or whatever, but no spinning! Every other cycle in the machine works perfectly. I can get it to spin if flip the switch back and forth for the load level from small, to med to large back and forth several times. After doing this, the spin cycle will kick in to gear and work fine. What does anyone think? Repair places such as sears want $129 just to come and look!
downtick is offline   Reply With Quote
Old 01-02-2012, 09:02 PM   #2
sounds like it may be a timer going bad.. that whats advances to the different cycles...
Old 01-02-2012, 09:10 PM   #3
after doing some more digging, do you think it could possibly be the water pressure level switch? I mean switching the load level switch back and forth gets the thing going, is that a possibility?
Old 01-02-2012, 09:15 PM   #4
thats a possibility... if you can find it you can bypass it by unplugging the wires and connecting them togeother and try it....I don't think thats it because the machine would most likley spill water...
Old 01-02-2012, 09:18 PM   #5
yes, i see most people with this switch problem have an over flow issue. With me, it only happens when the spin cycle is suppose to kick in. I figured I would buy one of these switches on ebay new for $20 and give a try. It seems easy enough to remove and put the new one in. In any event, why would switching the load level switch back and forth kick the spin cycle into gear? This leads me to believe there may be a problem with this switch and possibly the timer as well, but I am not a plumber or any kind of repair tech.
Old 01-02-2012, 09:24 PM   #6
can you see the pressure switch..and can you bypass it before you buy one......as far as moving load switch back and forth....I think that to is controled by timer and could be allowing power to be interfering with normal switching
Old 01-02-2012, 09:28 PM   #7
I don't know how to bypass it exactly. It scares me a little doing that, I figure for $20 I would give it a shot, a neighbor who has some background in appliance repair had a look at it and he is the one who told me first look at pressure switch, next look at timer.
Old 01-02-2012, 09:37 PM   #8
fair enough you are doing exactly what we reccommend if you are not comfortable doing something "don't do it" do what your comfortable with...let us know...ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
downtick (01-02-2012)
Old 01-03-2012, 12:45 AM   #9
Sounds as if you might have a shorted part or faulty timer. Do you have a model # so we can seewhat you are working with ?
acestarservices is offline   Reply With Quote
Old 01-03-2012, 07:38 AM   #10
It is GE model number: WCSR2090D5WW
For now machine is working, somewhat. When it gets to spin cycle, I just flip the switch back and forth for water level and that will get it going. But I cannot continue this way.
Old 01-03-2012, 11:42 AM   #11
Take th front panel off of the washer. On the left side of the drum there is a thin clear hose that runs from the bottom of th drm up to the load size knob. Does the bottom of this hose look clogged? If so, you can pul it off and trim off an inch or so, reconnect it and try again. Either this hose is clogged or the knob for th load size is bad. Either way, be careful! This will eventualy cause the machine to continuously fill and eventually flood your house.
jfrotten is offline   Reply With Quote
Old 01-03-2012, 12:07 PM   #12
If the hose were clogged though, would flipping the load switch around get the machine to spin? I will have a look at the hose for sure, but I am still leaning towards the switch or the timer. To me, it seems like something in this load switch is faulty and moving it back and forth corrects it for a moment to allow the timer to trigger the spin cycle, but what do i know...this is what it appears to me only.
Old 01-03-2012, 07:18 PM   #13
#1 HAWKEYE FAN
hardwareman's Avatar
the water level switch will not fix your problem, that switch's purpose is to regulate the water level in the tub. If bad it can overfill, and or prevent the washer from agitating but has nothing to do with the spin cycle. I would have to guess that by messing with the switch you are just jarring something in the timer . Next time it acts up instead of messing with the water level switch push in and pull out on the timer knob and I'll bet you get the same results.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-03-2012, 07:23 PM   #14
i will try that. I bought a switch for only $20 shipped. I will give it a try, nothing to loose. If that does not work, I will get a new timer. I found them for under $70. I never replaced one before, but I watched some youtube videos on doing it with a GE washer and it looks quite easy, for both of them!
The Following User Says Thank You to downtick For This Useful Post:
ben's plumbing (01-03-2012)
Old 01-04-2012, 10:48 AM   #15
There are 3 things that will stop this model from spinning; a bad timer, a bad lid switch or a bad vacuum switch/line (load size selector).
Strainer in washing machine discharge line? bwendholt Plumbing 7 12-04-2011 07:01 AM
Manitowoc Ice Machine problem TNSmith Appliances 8 04-28-2010 12:48 PM
Drain hose stuck on washing machine savingedmund Plumbing 3 05-10-2009 11:19 AM
Cold water hose - washing machine cmcgowan Plumbing 1 01-08-2009 11:13 AM
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 08:47 PM
