GE Washing Machine Died - Appliances - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 06:13 PM   #1
I have a GE washer model WBB4500G0WW I put 2 comforters in there thinking it wouldn't over load it when I came back the washer was off and filled with water and the dispenser was filled with liquid fabric softner. I took the comforters out tried to drain the washer and nothing.
I tried everything I checked the breaker I checked the outlet. The outlet has power but when I plug the washer in it doesn't recieve power there are no lights lighting on the control panel. I changed the line filter thinking maybe that was the problem but still nothing. I have tried everything even the reset codes they talk about leaving it unplugged plugging it back in lifting the lid up and down 6 times nothing has worked for me. I took all the water out of the washer by hand. Please help.
UnicornSpirit is offline   Reply With Quote
Old 05-22-2011, 06:43 PM   #2
Stay-at-home GC
Hmmm.
The only time I've had the tub full of water, the sensor that ensures that the door is closed was broken. But it sounds like you have no power?
Are there usually lights on the front of the machine?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-22-2011, 07:00 PM   #3
Yes there are lights on the front panel of the Machine to indicate the diffrent cycles. The lights are currently not working
Old 05-22-2011, 07:48 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
control board WH12X10404 . retail $102.00
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-22-2011, 10:02 PM   #5
Do you know what would have caused that to quit working? And if I install a new one is there any chance it could short out too?
Old 06-10-2011, 04:09 PM   #6
Well I bought the control board installed it and still nothing happens. Could it be the motor?
Old 06-14-2011, 07:29 AM   #7
the pump would still run. did you change over the model select plug that was on your old control??
Jacques is offline   Reply With Quote
Old 06-14-2011, 09:50 PM   #8
Sorry that you got bad advice and changed the expensive control board (Everybody always assumes it is the board.) There is a tiny in line fuse in the wiring harness between the motor and the control panel.
If you remove the front panel the wires are taped together running up the right hand side if you are facing the front of the machine. This is more of a fusable link rather than a fuse and is wrapped in black tape. You can change out the fuse for a few bucks.
Good luck.
Kevster is offline   Reply With Quote
Old 06-15-2011, 07:29 AM   #9
The pump will still run-fuse is only for mtr/inverter
Old 06-15-2011, 09:12 AM   #10
#1 HAWKEYE FAN
Good luck.
like Jacques said that fuse will not prevent the pump from running.
replacing that fuse will get you no where in this situation.
Old 08-04-2011, 05:05 PM   #11
Ok so I got a new contol board, new line filter, and a new motor/inverter. Still no luck. We are now looking at the fuse.
Old 08-08-2011, 07:45 PM   #12
Ok we now replaced the fuse. Still no luck.
Old 08-08-2011, 09:56 PM   #13
#1 HAWKEYE FAN
no lights on control panel? do you have a voltmeter?
Old 08-10-2011, 12:41 PM   #14
My husband burned it out.
Old 08-10-2011, 02:48 PM   #15
#1 HAWKEYE FAN
thats to bad, get a new one and we'll troubleshoot this thing for you. After all the time and money you have into it you can't stop now
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 06:10 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
