GE Washing Machine Died
I have a GE washer model WBB4500G0WW I put 2 comforters in there thinking it wouldn't over load it when I came back the washer was off and filled with water and the dispenser was filled with liquid fabric softner. I took the comforters out tried to drain the washer and nothing.
I tried everything I checked the breaker I checked the outlet. The outlet has power but when I plug the washer in it doesn't recieve power there are no lights lighting on the control panel. I changed the line filter thinking maybe that was the problem but still nothing. I have tried everything even the reset codes they talk about leaving it unplugged plugging it back in lifting the lid up and down 6 times nothing has worked for me. I took all the water out of the washer by hand. Please help. |
Hmmm.
The only time I've had the tub full of water, the sensor that ensures that the door is closed was broken. But it sounds like you have no power? Are there usually lights on the front of the machine? |
Yes there are lights on the front panel of the Machine to indicate the diffrent cycles. The lights are currently not working
control board WH12X10404 . retail $102.00
Do you know what would have caused that to quit working? And if I install a new one is there any chance it could short out too?
Well I bought the control board installed it and still nothing happens. Could it be the motor?
the pump would still run. did you change over the model select plug that was on your old control??
Sorry that you got bad advice and changed the expensive control board (Everybody always assumes it is the board.) There is a tiny in line fuse in the wiring harness between the motor and the control panel.
If you remove the front panel the wires are taped together running up the right hand side if you are facing the front of the machine. This is more of a fusable link rather than a fuse and is wrapped in black tape. You can change out the fuse for a few bucks. Good luck. |
The pump will still run-fuse is only for mtr/inverter
replacing that fuse will get you no where in this situation. |
Ok so I got a new contol board, new line filter, and a new motor/inverter. Still no luck. We are now looking at the fuse.
Ok we now replaced the fuse. Still no luck.
no lights on control panel? do you have a voltmeter?
My husband burned it out.
thats to bad, get a new one and we'll troubleshoot this thing for you. After all the time and money you have into it you can't stop now:no:
| All times are GMT -4. The time now is 04:22 AM. |
