GE Washing Machine
I just recently replaced my timer due the fact it would fill up with water ,spin but not agitate on any cycle. After installing the part this morning I tested it and and went through a normal wash cycle. When I tried again a few hours later it did the same thing as before it would fill up with water ,spin but not agitate. I am assuming since it does spin the belt is fine. At this point I don't know if I have something shorting it out or I have a bad switch lid which is magnetic or if I have a bad rely. Also I would I bypass the lid switch on this machine so that I can see if that is the case.
Thanks,
Brian
