GE Washer Won't Stop Filling - Appliances - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 08:56 AM   #1
GE washer won't stop filling
Ge washer (topload) did not stop filling with water in the first cycle. What could be the problem?
probo is offline   Reply With Quote
Old 05-25-2009, 11:54 AM   #2
If you have to cut the water off going to the washer to stop the water the water valve is bad and needs replacing.
If turning the washer off stops the water flow the problem is either the water level control or the tube that runs from the control to the tub is stopped up. Most likely the tube is stopped up. Remove the front then look at the bottom left of the tub. You should see a box with the tube connected to it remove it. Often this tube will stop up right at the end and you can clean it out with a toothpick. Hope this helps!
Last edited by Scuba_Dave; 09-30-2010 at 11:39 AM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
