GE Washer Trouble - Appliances - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 01:02 PM   #1
GE Washer trouble
I have a GE washer mod WBSE2090A2WW that will not agitate or spin. Motor is not humming, clicking, etc. Any ideas out there before my wife divorces me? I would get someone to come and look at it but there is noone within 50 miles. Thanks.
WTX_Danny is offline   Reply With Quote
Old 02-17-2012, 03:06 PM   #2
Timer contacts burnt?
Old 02-17-2012, 04:12 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Door open safety switch?
The air tube that tells it when its full of water?
titanoman is offline   Reply With Quote
Old 02-18-2012, 02:23 PM   #4
No, they look fine.
Old 02-18-2012, 02:24 PM   #5
Is there a way I can test those?
Old 02-18-2012, 02:53 PM   #6
Disabled wood vet
titanoman's Avatar
I don't know how to get to the pressure tube to blow on it on your particular machine...you should be able to see it from the underside, about 6-8 inches long clear tube, going straight up and down next to the basket.
Use test light on switch at end of that tube while you blow on the other end, if possible.
You may have to remove assembly.
The other, get to the switch, right on top, under door edge, where the post on the lid goes into the hole, and test with test light (or bypass switch with jumper wire) when tub should be agitating or spinning.
Not sure how to get to backside of switch on your machine.
I used to rebuild wash machines, and the air tube was the problem more than once (dirty, plugged, broken).
The switch on top, not so much.
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 03:41 AM
Trouble getting tank straight with new spud washer darsunt Plumbing 1 07-28-2011 07:38 AM
honda pressure washer trouble electricman Automotive Repairs 6 06-03-2011 08:21 AM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
