Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 04-14-2010, 09:50 AM   #1
Ge washer motor runs slow
Have GE washer and the motor has started running very slow. It acts like it is not getting enough electricity. It is not the wall outlet because I ran an extention cord to a completly different outlet on a different circuit and it is still the same. When it does this it dims the lights on that circuit in the house. Any suggestions? Thank you
ROBBYT3 is offline   Reply With Quote
Old 04-14-2010, 04:10 PM   #2
It was a dark and stormy
Yoyizit's Avatar
Bad connection upstream of the machine and the dimming lights.
If some lights get brighter it's a bad neutral connection.
Check the voltage at the outlet with the symptom present. Check again with a hair dryer plugged in and running, and then shut off.
Old 04-14-2010, 04:27 PM   #3
So you think it's in the power and not the machine?
Old 04-14-2010, 06:41 PM   #4
Yoyizit's Avatar
With the lights dimming, I doubt it's the machine. Measure voltages and remove doubt.
Old 04-16-2010, 09:41 AM   #5
if it's not getting enough power it'll overheat and shut down. could be just a bad belt. need more info.. need model # to see what iteration of GE washer you have.. makes a difference.
Jacques is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General Discussion 3 08-23-2009 06:29 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
washer drain is draing slow mrmordun Plumbing 13 03-08-2009 11:45 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
