#1 |
GE washer makes noise when running, only one month old
Bought a GE 3.6 cu ft 24 cycle high efficiency washer about a month ago. Its makes a whine noise when the motor runs to turn the tub during the wash cycle. Is this normal, should I call a repair man? It has a one year parts/labor limited warranty, not sure if they would cover the service call. Bought thru Best Buy, model GTWN4950LWS
any advise would be appreciated |
#2 |
That washer mostly makes clunking noises that seem unusual. it will whine as it ramps up in spin. if you're concerned, call for warranty service so the tech can hear what you describe. yeah no charge first year. to avoid them trying to blow you off when you call [they're looking at a computer screen check list-trying to avoid cust' education calls]-tell them it just won't start but power is on. when tech comes explain actual problem.
#3 |
That whine noise on ramp up sounds to be what it is doing, you say that is normal?
I can live with it, just wanted to verify it wasnt broken, Thanks |
#4 |
That drum spins about twice as fast as a top load if that's what your used to. And yes it makes more noise.
| Display Modes | |
| GE Washer WVSR1060A0WW noise problem | gflippen | Appliances | 0 | 03-03-2010 09:23 AM |
| Pipe noise upstairs bathroom when running only warm water | dial2fast | Plumbing | 1 | 12-04-2007 12:39 AM |
| Is it possible I have a 220 running to my dish washer? | aljanney | Electrical | 25 | 02-15-2007 11:08 PM |
| running washer drain | sedwick | Plumbing | 8 | 02-12-2007 06:10 PM |
| Running Water makes pipes moan | MikeRatliff | Plumbing | 2 | 01-25-2007 07:47 PM |
