GE Washer Machine Noise - Appliances - DIY Chatroom Home Improvement Forum
Old 12-17-2007, 09:30 PM   #1
GE washer machine noise
I have a GE washing machine that sounds like a bearing has gone on the motor. When I opened the bottom access panel, the noise seems to be coming from the assembly directly under the drum. It looks like there is dark colored grease on some of the surrounding parts. Any suggestion or advice would be greatly appreciated.
Thanks for your help
superiorbuilt4u is offline   Reply With Quote
Old 12-18-2007, 05:55 AM   #2
How old is the unit?
Could be the pump going bad if it is not the motor.
redline is offline   Reply With Quote
Old 12-18-2007, 07:27 AM   #3
The unit is 6 years old. The noise seems to be coming from directly under the the drum during the spin cycle to remove the water from the clothes
noisy washer agitator bucksone Appliances 43 03-06-2014 07:49 AM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 02:45 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
