GE Washer Has More Than One Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 06:40 PM   #1
GE Washer has more than one problem
This is going to be complicated. First my washer was turning off by it self during the second fill. It would be filled with clean rinse water and would just stop. I would repress the on button and it would go on and then finish just fine. That went on for a couple weeks and I just dealt with it because it didn't do it everytime, I think it depended on which cycle it was on.
Then all of the sudden it started agitating like it was restricted, like it wasn't agitating smoothly, more like clunking little short jerking back and forth. At the same time with every loud jerk my lights in my house with flicker like it was affecting the electrical.
Sorry not done yet.
When that started happening it stopped spinning right at the end of the rinse cycle, therefore the clothes were still wet enought that I had to hand ring them out.
I told you it was complicated. I looked in my manual and it's not surprising that there wasn't a catagory that fit these descriptions.
Any ideas?
Lilybelle is offline   Reply With Quote
Old 10-30-2010, 06:53 PM   #2
HVAC / Plumbing
Sorry not done yet.
Any ideas?
Maybe a transmission and or timer problem
kenmac is offline   Reply With Quote
Old 10-31-2010, 10:58 AM   #3
Thank you for your answer, do you think this would require hiring someone or is it possibly a DIY?
Old 10-31-2010, 02:48 PM   #4
Rewards Points: 6,652
Both are DIY if you have the time and patience to do it.
Old 10-31-2010, 03:06 PM   #5
Rewards Points: 472
Check the prices and you will find that it is time to get a new one with warrenty. Work done. The transmision is no fun to change . You have to get it right Their is a boot to keep water where it is sopose to be. Now the timmer if that is bad more money? Could be water sencer's ?? You just keep putting part's in and than you will have like a new maching with no warrenty. And maybe you will not get it fixed and have all those part's?? I would advise you to just get a new one and send the problum's away.
del schisler is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
