GE Washer Extremely Loud & Lots Of Movement - Appliances - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 02:12 AM   #1
GE Washer extremely loud & lots of movement
I have a GE WJSR2070, it is leveled. The basket is tilted to the right side, this started after my grandmother overloaded it with quite a few heavy comforters. I've tried swapping the basket support (left to right, right to left, did this on both front and rear sets), and the basket is still tilted to the right. I've also disconnected the drain pump, and emptied out the water, but the basket is still tilted to the right. Any other ideas what it might be?
Oliver126 is offline   Reply With Quote
Old 01-02-2011, 07:58 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
is just the inner basket tilted or are both the inner and outer tub tilted
hardwareman is offline   Reply With Quote
Old 01-03-2011, 12:32 AM   #3
the whole basket, tub assembly is tilted
Old 01-03-2011, 06:21 PM   #4
#1 HAWKEYE FAN
and you said you switched the suspension rods? what do the ball that the suspension rods attach to look like?
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 06:29 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
