GE Washer - Drum And Agitator Seem Stuck Together - Appliances - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 07:14 PM   #1
Rewards Points: 372
Question
GE Washer - Drum and agitator seem stuck together
Hi all,
My stepson has a GE WJRE5550 clothes washer and the agitator doesn't operate properly.
The washer goes through all the cycles, but when it should be just sloshing the agitator the drum moves too - thus not properly agitating.
When we popped the front there is a little circuit board down low on the right side of the mechanism and the light on it flashes four times, then pauses, then flashes four times, etc.
Anybody have any idea of what the problem might be?
Last edited by imautoparts; 06-06-2013 at 08:42 PM. Reason: edit - updated/correct model number
imautoparts is offline   Reply With Quote
Old 06-06-2013, 07:39 PM   #2
Rewards Points: 372
Additional Info
According to a GE fault code sheet I found online the four flashes should mean:
"CHECK MODE SHIFT CIRCUIT FAIL"
Followed by the instructions to check the mode shifter coil.
What is the mode shifter coil, what does it look like and where approximately might I find this in the washer?
Old 06-06-2013, 08:06 PM   #3
Rewards Points: 12,830
That model # does not come up.
http://www.repairclinic.com/RepairHe...-won-t-agitate
Old 06-06-2013, 08:37 PM   #4
Rewards Points: 372
Hey Joe,
Seems you always help me out. Sorry I typed the model # wrong.
It is a WJRE5550KZWW.
