Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-30-2008, 12:29 PM   #1
GE Washer Clutch Slips
I replaced the clutch on my top loading GE washer when it refused to spin. But now the clutch itself is slipping like crazy. I've tried the belt at various tensions, but nothing works. The seller assures me that the clutch is OK. What else could I be doing wrong? Thanks,
Edward
trevelyan is offline   Reply With Quote
Old 05-30-2008, 03:52 PM   #2
jeff1's Avatar
Hi,
Model#?
http://www.applianceaid.com/model.html Some model# helps.
Fill, agitation and draining works ok?
Clutch us suppose to slip and allow the basket to slowly come up to speed. What happens instead of spinning?...any noises?...basket moves at all?
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 05-31-2008, 09:59 AM   #3
Hi Jeff. Thanks for getting back to me. It's a GE model WSSR3120W0WW top loader.
The drain and agitation functions seem OK. It just won't spin. I realize that the clutch is supposed to slip as the basket comes up to speed. However, my clutch doesn't allow the basket to EVER start moving unless I have a very light load. Instead, the shaft from the motor just slips in the clutch, and obviously the belt remains motionless. One would conclude that the clutch is shot, but my seller assures me that the part was brand new.
Edward
Old 05-31-2008, 03:23 PM   #4
jeff1's Avatar
WSSR3120W0WW
Plastic tub GE washer.
Good.
The motor drives the clutch, the clutch turns the belt, the belt turns the tranny pulley, the whole tranny turns and the basket is mounted to the upper shaft of the tranny....clothing between the tanks, tight/seizing tub bearing, bad/locking up tranny, tub supports worn and the tub is binding on the outer holding tank, something caught in one of the tub holes would be prime suspects.
Since -some- spinning will occur, clothing between the tanks, tight/seizing tub bearing, bad tranny would be my guesses.
Large pulley in the middle can be manually turned to see if stiff or not....belt off first.
Rare to occur, normally gets noisy if worn inside..often soemthing else ( like above ) is holding the outer shell of the clutch back from turning.
jeff.
JRAppliance
Old 05-31-2008, 04:22 PM   #5
Thanks Jeff: I'll check those things. Didn't know clothes could get caught between tanks. My guess is that replacing the tranny wouldn't be worth it on this relatively old machine. Would you agree?
Edward
Old 05-31-2008, 04:43 PM   #6
Jeff: Can I check for clothing between tanks without removing the hanging tank assembly?
Old 05-31-2008, 05:40 PM   #7
OK, I removed the belt and checked the pulley (to see if stiff or not). The pulley turns quite freely counter clockwise (looking upward) for about 5 rotations. It then gets stiff for about one rotation, after which it becomes free again. Can you tell from this description if the tranny is OK? Thanks,
Edward
Old 05-31-2008, 11:22 PM   #8
jeff1's Avatar
Agitation is attained by turning the transmission in a clockwise motion. Spin occurs when the transmission is turned in a counter clockwise motion.
Since we cannot test ourselves, nope....but doesn't -sound- good
jeff.
JRAppliance
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
Pressure Washer Question DIYchick Tools 8 02-05-2008 06:44 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
