Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-02-2009, 07:31 PM   #1
Default GE Washer Belt Replacement
Hey guys, i am new to the site and would appreciate any help given. I have a ge washer model # WJSR4160G2WW with a broken belt. I have the new belt in hand but can't figure out how to get a belt that barely fits around the large pulley on the tub to also go around the motor shaft. I have already removed the four nuts securing the motor, but that didn't help any. Please help!
lcortez is offline   Reply With Quote
Old 10-02-2009, 09:20 PM   #2
biggles's Avatar
put the motor back with all the nuts and bolts put the belt on the motor pully then with your hand put the belt into the drum pully at an angel turning the drum slowly it will slip into the groove as it goes around.on any pully situation you put it in the groove of the smaller one and feedit into the bigger one..there is no adjustment it is 2 fixed points shaft to shaft http://www.repairclinic.com/Washing-...liance-Diagram right click this image to ZOOM in on the pully section
Old 10-02-2009, 10:13 PM   #3
Default Ge washer belt
Thanks Biggles, I think that I tried that with no luck. I will try it again in the morning with a little more patience and post the outcome.
Old 10-02-2009, 11:03 PM   #4
biggles's Avatar
once you get a hand full of belt in the drum pully groove give it a hard spin and the rest of the belt will snap in.....watch those fingers and it might seem tight due to it being new.
Old 10-03-2009, 12:19 AM   #5
I'm not sure if we are talking about the same model, but my tub pulley does not have a groove. It has a smooth face with no groove for the belt to ride in. The belt has five small ribs in the surface and it is my understanding that once in place one rib will be visable either from the top or bottom of the pulley(does not matter which).
Old 10-03-2009, 01:59 PM   #6
biggles's Avatar
you got me on that one you can go to that site i gave you and ask questions for that situation on the grooved belt and flat drum pully...good luck
Old 10-03-2009, 07:23 PM   #7
Thanks Biggles, mission accomplished. I coupled your advice with the advice from another forum which was to tilt the washer and lean it against the wall, then drop the bottom panel. That gave me the extra access that I needed to put your plan to work. The belt was on in minutes and being loaded for a test run. Once again, thanks for all your help.
Old 10-04-2009, 02:46 PM   #8
biggles's Avatar
REMEMBER.............seperate the whites
Old 10-27-2009, 02:38 PM   #9
Thumbs up My Advice: it takes two!
Yo-
I had the same issues with the same washer and finally broke down and called in an appliance repair guy. He said the same thing and actually told me that I have the wrong belt. After making a couple of calls, he said we had the right belt and it may take two of us to put on the belt.
We first put the belt on the motor pulley and then started it on the larger pulley until it was very tense. We then clamped a vise grip on that spot (the larger pulley) where the belt would start to slip off. So, I made sure that the belt did not come off the motor pulley as the repair dude spun the larger pulley and booyah!!
This is probably confusing to anyone, unless you have been in this situation before.....crazy!!
Good Luck and it was the best $40 I have spend for 10min. of teamwork.
phenom517 is offline   Reply With Quote
Old 10-27-2009, 11:52 PM   #10
They make a tool to help put this type belt on (part # WX05X10102) although I am not quite sold on how well it works. Bottom line that belt is a pain to replace!! http://www.appliance-repair-it.com/c...er-repair.html
applianceman is offline   Reply With Quote
Old 11-04-2009, 09:02 AM   #11
you just put a plastic wire tie on belt and large pulley at the point you're going to start at-then run belt on and cut wire tie off.....usually when this belt breaks there's a bigger problem-motor and or mode shifter.
Jacques is offline   Reply With Quote
More On This Topic
Chevrolet replaced fan belts with serpentine belts that run everything in your car from the cooling system to the electrical system. This, of course, means they're much more difficult to replace than the old fan belts. Follow these tips for correctly... Read More »
The serpentine belt makes engine designs simpler and easier to maintain. The downside of one, single belt is, of course, that if it fails every major system in your Lincoln will shut down. This makes proper inspection and maintenance of your Lincoln's... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about proper use and maintenance of a pressure washer. As we mentioned, some pressure washers are gas and some are electric. Obviously... Read More »
Remove the front pulley, getting the accessory drive pulley off of the crank when repairing a cracked cylinder head; learn more in this free auto-restoration video. Read More »
In this clip I'm going to talk to you about the wood lathe. This is a wood lathe that is used to hold the bowl blank, the material for turning. This is the head stop. This is where the motor is that drives the piece spinning while you cut the wood. It is... Read More »
Washer: Loose belt - won't spin Hemingway Appliances 5 06-06-2009 07:35 PM
Belt care... RippySkippy Tools 3 12-25-2008 03:43 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 1 03-04-2008 06:44 PM
Dish washer replacement 68MHJCs Appliances 1 02-08-2008 03:20 PM
Snow blower drive belt replacement help lwhiten395 General Discussion 5 01-15-2008 05:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
