-   -   GE Washer Belt Replacement (http://www.diychatroom.com/f47/ge-washer-belt-replacement-54314/)
lcortez 10-02-2009 05:31 PM
Hey guys, i am new to the site and would appreciate any help given. I have a ge washer model # WJSR4160G2WW with a broken belt. I have the new belt in hand but can't figure out how to get a belt that barely fits around the large pulley on the tub to also go around the motor shaft. I have already removed the four nuts securing the motor, but that didn't help any. Please help!
biggles 10-02-2009 07:20 PM
put the motor back with all the nuts and bolts put the belt on the motor pully then with your hand put the belt into the drum pully at an angel turning the drum slowly it will slip into the groove as it goes around.on any pully situation you put it in the groove of the smaller one and feedit into the bigger one..there is no adjustment it is 2 fixed points shaft to shaft http://www.repairclinic.com/Washing-...liance-Diagram right click this image to ZOOM in on the pully section
lcortez 10-02-2009 08:13 PM
Ge washer belt
Thanks Biggles, I think that I tried that with no luck. I will try it again in the morning with a little more patience and post the outcome.
biggles 10-02-2009 09:03 PM
once you get a hand full of belt in the drum pully groove give it a hard spin and the rest of the belt will snap in.....watch those fingers and it might seem tight due to it being new.
lcortez 10-02-2009 10:19 PM
I'm not sure if we are talking about the same model, but my tub pulley does not have a groove. It has a smooth face with no groove for the belt to ride in. The belt has five small ribs in the surface and it is my understanding that once in place one rib will be visable either from the top or bottom of the pulley(does not matter which).
biggles 10-03-2009 11:59 AM
you got me on that one you can go to that site i gave you and ask questions for that situation on the grooved belt and flat drum pully...good luck
lcortez 10-03-2009 05:23 PM
Thanks Biggles, mission accomplished. I coupled your advice with the advice from another forum which was to tilt the washer and lean it against the wall, then drop the bottom panel. That gave me the extra access that I needed to put your plan to work. The belt was on in minutes and being loaded for a test run. Once again, thanks for all your help.
biggles 10-04-2009 12:46 PM
REMEMBER.............seperate the whites:thumbup:
phenom517 10-27-2009 12:38 PM
My Advice: it takes two!
Yo-
I had the same issues with the same washer and finally broke down and called in an appliance repair guy. He said the same thing and actually told me that I have the wrong belt. After making a couple of calls, he said we had the right belt and it may take two of us to put on the belt.
We first put the belt on the motor pulley and then started it on the larger pulley until it was very tense. We then clamped a vise grip on that spot (the larger pulley) where the belt would start to slip off. So, I made sure that the belt did not come off the motor pulley as the repair dude spun the larger pulley and booyah!!
This is probably confusing to anyone, unless you have been in this situation before.....crazy!!
Good Luck and it was the best $40 I have spend for 10min. of teamwork.
applianceman 10-27-2009 09:52 PM
They make a tool to help put this type belt on (part # WX05X10102) although I am not quite sold on how well it works. Bottom line that belt is a pain to replace!!
Jacques 11-04-2009 07:02 AM
you just put a plastic wire tie on belt and large pulley at the point you're going to start at-then run belt on and cut wire tie off.....usually when this belt breaks there's a bigger problem-motor and or mode shifter.
