Ge Washer Agitator Top Half Is Loose - Appliances - DIY Chatroom Home Improvement Forum
Old 08-06-2013, 08:10 PM   #1
Rewards Points: 31
Ge washer agitator top half is loose
how do I get agitator apart
upnorthdennis is offline   Reply With Quote
Old 08-06-2013, 08:16 PM   #2
Rewards Points: 31
I can pull agitator out of washer but can not separate 2 pieces to tighten
Old 08-07-2013, 06:11 AM   #3
Rewards Points: 13,458
Got a model #?
Old 08-07-2013, 07:50 PM   #4
Rewards Points: 31
ge washer
model # S3500BOWW
Old 08-07-2013, 08:36 PM   #5
Rewards Points: 6,652
The Agitator should be two assemblies. You pull the top off, and the main part will have a cap, that you remove and then there should be a nut in there, that you loosen to pull that assembly off the transmission shaft.
There are some units, that the agitator is actually two sections, which you can remove the top section, when you have a larger load, that is the part that you are stating is loose. Here is the Care & Use book for your model, if you do not have it around http://products.geappliances.com/Mar...e=49-90144.pdf
Old 08-10-2013, 02:26 PM   #6
Rewards Points: 31
agitator
I see that cap on inside but I can't get off I thought that should come out but it does not that is problem I have how do I get that cap out
Old 08-10-2013, 02:42 PM   #7
Usually stuff like fabric softener will cause it to stick. A screw driver will pop it, or a butter knife. Pouring boiling hot water over it, helps to allow you to pop it off.
leveling washer gt1935 Appliances 5 02-04-2013 04:57 AM
Switch Washer & Dryer Position? Anianna Appliances 5 12-12-2012 10:55 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
