GE Wall Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 05:41 PM   #1
GE wall oven
bottom element won't heat up-even after replacing it just gets warm. Also changed fuse.
1074 is offline   Reply With Quote
Old 12-13-2010, 10:07 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
electronic control board or do you have a mechanical clock and thermostat? did you verify 220 volts going to unit or just assume since you replaced fuse that it was getting proper voltage?
hardwareman is offline   Reply With Quote
New wall oven has 4 wires wall has three hobiecatman Electrical 5 10-05-2010 07:19 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 05:45 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
