GE Upright Deep Freeze - Horrible Smell - Appliances - DIY Chatroom Home Improvement Forum
Old 06-26-2015, 02:21 AM   #1
Rewards Points: 2
I'm new and this is my first post, so I hope I'm doing this right. We have an upright GE deep freeze. It's 6 years old and located in our washroom. For about a week now, we've been noticing a progressively more pungent odor coming from the room that smells like strong moth balls. We've cleaned, thrown food away, looked for dead rodents, etc with no success. Tonight I slid the freezer out from the wall and looked underneath. The smell almost blew me away. Seems like it's coming from the black, pressurized canister underneath. (Sorry but I'm a novice at appliances.)
Could this be a gas leaking out of this canister? Or any other ideas of what this smell could be?
Thanks so much for your help!
Popdaddy is offline   Reply With Quote
Old 06-26-2015, 06:08 AM   #2
DIY staff
Rewards Points: 7,174
That black canister is the compressor---so---I think the unit is failing--time to call a repair man or buy a new unit.
Old 06-26-2015, 08:53 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I would have no idea why a compressor would smell horrible just because it was failing. My guess is there is something under there rotting.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
jmon (06-26-2015)
Old 06-26-2015, 10:11 AM   #4
Rewards Points: 218
As mentioned, investigate a little more closely around the compressor area and underneath with a good flashlight and rule out any dead varmints first as the source of the smell. Go from there.
jmon is offline   Reply With Quote
Old 06-26-2015, 01:41 PM   #5
Rewards Points: 83
Refrigerant doesn't smell. Burning coils/wires/transformers do, but you'd know of an issue typically pretty quickly. I would go with the already stated and try and find where the dead animal is. I would probably unload the entire thing and pull the entire unit out.
Protocol. is offline   Reply With Quote
Old 07-03-2015, 02:38 PM   #6
Rewards Points: 6
To me, a mothball smell wouldn't indicate rotting flesh. it sounds more like an electrical or burning problem, or some kind of chemical decomposition.
Rotting mouse (or other critter) aroma, to me, is very different than electrical or other burning smells. Freon that is heated above something like 600 degrees can decompose into phosgene gas. I'm not sure what newer refrigerants do under the same conditions.
To me, the moth ball type smell is a clue. I'd be careful, and try to figure this out quick. If something is burning or getting hot enough to produce that kind of smell, it needs to be fixed or unplugged ASAP.
Is the OP familiar with dead animal smell? Identifying smells is a very useful troubleshooting gift or skill. Don't ignore the information smells provide.
jsigmo is offline   Reply With Quote
Bad smell in certain parts of house in warm weather roboth General DIY Discussions 26 07-18-2014 08:20 PM
deep freeze keeps running Master Brian Appliances 7 03-25-2013 10:50 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
