Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-13-2009, 08:29 PM   #1
GE THF24PR Refrig/Freezer icemaker
The icemaker dispenses crushed ice in both the cube and crushed ice positions. Water is dispensed properly. I pulled the ice storage bin out and found a loose solid metal cylinder (1 7/8 inches long and about 1/2 inch in diameter) with a hole through the cylinder near one end. Any ideas what the part is--I assume it is related to my problem. How can I fix my problem?
Thanks in advance.
artaman is offline   Reply With Quote
Old 03-16-2009, 08:10 PM   #2
The piece that you found,is part of your solenoid.The solenoid,is located on the back side of the cover at back of freezer. The solenoid,switches the bucket door,from cubed to crushed.You'll have to get the panel out,to see what's going on.
d scott is offline   Reply With Quote
Tags
crushed, cube, freezer, ge ice maker
Copper tubing for icemaker? BigJimmy Plumbing 15 09-11-2011 03:23 PM
Kitchenaid icemaker jack14246 Appliances 1 12-18-2008 05:06 PM
Kenmore Icemaker install Turnerg110 Appliances 2 07-21-2008 04:55 PM
Whirlpool Icemaker Stopped Working jablizz General Discussion 1 07-19-2008 09:38 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 03:07 PM
