GE TBX21JI Freezer Works, Fridge Not Cold - Appliances - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 11:49 AM   #1
GE TBX21JI Freezer works, fridge not cold
I'm trying to help an elderly woman with this problem.
I noticed that the freezer had a lot of frost built up, I defrosted it but the fridge is still 60F.
(Freezer is 20F)
I have been told there is a fan that blows cold air from the freezer to the fridge. I noticed that the temp control for the freezer opens/closes what looks like an air inlet into the fridge, there is no air blowing in.
How do I determine if this fan is bad, and where is it located?
Could it be another problem such as the fridge temp control or a relay or sensor?
This nice lady has no fresh food, and a fixed income. Please help.
Cal Jader is offline   Reply With Quote
Old 10-17-2013, 03:11 PM   #2
Rewards Points: 13,732
http://www.repairclinic.com/RepairHe...ot-cold-enough
Old 10-17-2013, 05:59 PM   #3
biggles's Avatar
wipe the gaskets and door frames top and bottom.need to seal tight especially on that freezer with leakage causing ice build up...the frig part is a damper door as where cold air drops down into the lower section to the frig setting then closes as it is satisfied the air blowing is the freezer fan...
Fridge Too Warm Then Too Cold - Help! marcus118 Appliances 3 06-27-2013 02:01 PM
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 08:32 AM
Hotpoint freezer cool fridge too cool Maddyrosedad Appliances 1 02-19-2009 05:38 AM
freezer leaking into fridge - cannot locate drain hole pro_DIYer Appliances 5 12-31-2008 11:08 PM
Can I save my Magic Chef Fridge. The Freezer works but the fridge doesn't bmfay10 Appliances 2 03-28-2008 12:54 PM
