Ge Sr3100woww Wshing Machine No Spin - Appliances - DIY Chatroom Home Improvement Forum
Old 05-16-2010, 09:14 AM   #1
ge sr3100woww wshing machine no spin
Will not spin when fully loaded but if you put a small load in it spins fine. Suspect drive belt is loose ??
Thanks Chuck
747driver is offline   Reply With Quote
Old 05-16-2010, 10:28 AM   #2
Could also be the belt tensioner if it has one.
Old 05-19-2010, 08:06 AM   #3
Rewards Points: 530
Is it belt driven? Check drive block or dogs in the top of the agitator. Or, it may be a clutch problem.
Solid back cabinet? If so, most likely a direct drive motor. Check the motor coupling.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
GE Washing Machine - No Spin? BDPNA Appliances 12 05-12-2011 12:40 PM
help with specs and spin info on older washing machine wombosi Plumbing 5 04-27-2009 05:57 PM
Washing Machine Not Reaching Max Spin Shelley Appliances 2 11-30-2008 09:12 PM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
