-   -   ge sr3100woww wshing machine no spin (http://www.diychatroom.com/f47/ge-sr3100woww-wshing-machine-no-spin-71312/)
747driver 05-16-2010 09:14 AM
Will not spin when fully loaded but if you put a small load in it spins fine. Suspect drive belt is loose ??
Thanks Chuck
Yoyizit 05-16-2010 10:28 AM
Could also be the belt tensioner if it has one.
boman47k 05-19-2010 08:06 AM
Is it belt driven? Check drive block or dogs in the top of the agitator. Or, it may be a clutch problem.
Solid back cabinet? If so, most likely a direct drive motor. Check the motor coupling.
