GE Spacemaker Microwave No Heat - Appliances - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 07:54 PM   #1
GE Spacemaker microwave no heat
I have a 2004 GE Spacemaker over the range microwave that will not heat and everything elese works fine. Model JVM1440BH01 Need help. Thanks
Modapu30 is offline   Reply With Quote
Old 10-16-2011, 08:22 PM   #2
Project Manager
KJINTF's Avatar
Hi
Not sure of your technical ability and the tools you have at hand
I Googled repairing Microwave ovens and looked at a few You tube videos
Microwave ovens are really very simple devices anyone with any technical ability should easily be able to repair them
Safety is always a concern 2.4Gig radiaton and high voltage electricty at 60Hz
If the turntable moves, the lamps come on, the display works, and still not heat
There are only a few items that are left
The Capacitor - looking at your model they are asking $49.00 for a capacitor which you can get at a high end electronics store for $5.00
The HV Diode - I see they are asking $57.00 for the diode again I paid less than $3.00 for mine - if you are willing to solder and crimp wires
The transformer
The Magnetron
Several simple easy checks for each of the items
Mine turned out to be the diode being shorted - Sharps parts wanted as much as $30.00 for the assembly
I replaced the diode with a higher voltage temperature and current rated diode which cost me less than $3.00
KJINTF is offline   Reply With Quote
Old 10-17-2011, 09:01 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
Originally Posted by KJINTF View Post
Hi
The transformer
The Magnetron
Don't forget the door switches, the pcb board to see if it is putting out voltage, and thermal fuses
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
