-   -   GE Spacemaker microwave no heat (http://www.diychatroom.com/f47/ge-spacemaker-microwave-no-heat-120322/)
Modapu30 10-16-2011 06:54 PM
I have a 2004 GE Spacemaker over the range microwave that will not heat and everything elese works fine. Model JVM1440BH01 Need help. Thanks
KJINTF 10-16-2011 07:22 PM
Hi
Not sure of your technical ability and the tools you have at hand
I Googled repairing Microwave ovens and looked at a few You tube videos
Microwave ovens are really very simple devices anyone with any technical ability should easily be able to repair them
Safety is always a concern 2.4Gig radiaton and high voltage electricty at 60Hz
If the turntable moves, the lamps come on, the display works, and still not heat
There are only a few items that are left
The Capacitor - looking at your model they are asking $49.00 for a capacitor which you can get at a high end electronics store for $5.00
The HV Diode - I see they are asking $57.00 for the diode again I paid less than $3.00 for mine - if you are willing to solder and crimp wires
The transformer
The Magnetron
Several simple easy checks for each of the items
Mine turned out to be the diode being shorted - Sharps parts wanted as much as $30.00 for the assembly
I replaced the diode with a higher voltage temperature and current rated diode which cost me less than $3.00
hardwareman 10-17-2011 08:01 AM
Originally Posted by KJINTF (Post 750093)
Hi
The transformer
The Magnetron
Don't forget the door switches, the pcb board to see if it is putting out voltage, and thermal fuses
