-   -   GE Smart Digital Timer Flashes (http://www.diychatroom.com/f47/ge-smart-digital-timer-flashes-90242/)
Hawkus1939 12-22-2010 10:35 AM
I installed a GE Smart Digital timer today and after rechecking the programing an rechecking the wiring the switch causes the controled light to flash on and off. I woulld appreciate any ideas?
clashley 12-22-2010 10:40 AM
What is the model of the GE switch, and what sort of load do you have on it? (CFL/FL tube, incandescant, LED, etc.)?
Hawkus1939 12-22-2010 10:57 AM
Smart Digital timer switch
It is a model 15071 in wall clock operated switch. and is controling an incandescant 100 watt lamp.
clashley 12-22-2010 11:08 AM
This switch requires a neutral connection. It should have four leads (black, white, green, and red). The connections should be as follows:
  • Black lead connects to the hot wire coming from your breaker box.
  • Red Lead connects to the hot wire going to the light fixture.
  • White lead is pigtailed to the neutral wire coming from your breaker box and the neutral wire going to the light fixture.
  • Green lead is connected to ground.
If you don't have a neutral wire in the junction box, you'll need to pull a new wire to make the GE switch work. It's possible that the light fixture is wired on a switch loop, in which case the original wiring setup would not have a neutral in junction box.
When you removed the original switch, was it is a standard single-pole rocker, or a three-way switch? Also, how many wires are entering the junction box?
Hawkus1939 12-22-2010 11:17 AM
I replaced a single pole rocker switch with this Smart Digital timer switch. I guess that can not be done. I will have to reinstall the old switch.
Thanks anyway:(
