GE Side By Side-No Water - Appliances - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 06:04 PM   #1
GE side by side-No water
GE GSH25JSTA-SS refrigerator. No water at door dispenser. So far I have:
Checked supply line. Good.
Checked motherboard. Relay seems to be clicking.
Checked connector at water valve. Getting 120V at connector.
Took a hair dryer to holding coil to make sure it wasn't iced up inside the fridge.
Anything else I should check or just go ahead and order a new valve?
jerryh3 is offline   Reply With Quote
Old 12-20-2009, 08:17 AM   #2
disconnect water line in front [under grille] depress paddle, get water-yes=line inside door is frozen. if you have a metal interior [put magnet on inside of frz on wall] there's a htr kit avail to correct this[call local parts dist] if you have plastic interior door is shot...if no water to front disconnect you have other problems.
Jacques is offline   Reply With Quote
Old 12-20-2009, 03:40 PM   #3
Thanks for the tip. I have water flow at the connector so it's definitely an obstruction in the freezer door line. I lowered the set temperature of the freezer so hopefully it will clear itself. I do have a plastic interior.
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
