GE REfrigerator Water Line Replacement - Appliances - DIY Chatroom Home Improvement Forum
Old 10-02-2009, 10:13 AM   #1
Question
When using the water dispenser water flowed out from under the refrigertor. Traced the cause to a broken water line near the dispenser relay. Trying to replace the hose I find it routes through the refrigerator compartment where it is caulked (to prevent loss of cooling?). It appears difficult to replace the whole line because of this. For ease of repair I could just bypass the loop through the refrigerator which I believe just pre-chills the water to the dispenser. Is this advisable? If not recommended, what is the easiest way to get at the hose routing through the refrigerator. Note the broken hose appears darkend and has lots of cracks (looks like it may have been degraded by heat from the compressor). This makes me hesitant to just splice a new section onto it.
Tom the Amature is offline   Reply With Quote
Old 10-04-2009, 08:19 AM   #2
you didn't list a model & serial #-MAJOR ERROR- so don't know what you have. in any case, don't hack it up. it's not hard to replace the tubing. if this refrig is not ancient-your condenser fan may not be working,at all/erratic [causing tubing to overheat] was the unit area exceptionaly hot? this would be an indication of fan problems. with #'s go to local appliance parts store and buy what you need.
Jacques is offline   Reply With Quote
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
Main Line Replacement dreamsgoneawry Plumbing 8 01-10-2009 11:34 AM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 09:51 AM
